10 years agoLPM_FF megafunction
I want to use the LPM_FF megafunction for my project. I want the LPM_WIDTH to be 8. I added that in the parameter field. Quatra II is not recognizing the change even after I saved the BDF file. The c...
10 years agoI found it. It is called IP catalog.Thanks for your help. I have not tried it as I am stuck at another problem. Will check out tonight.
