LPM DIVIDE behaves differently between simulation and implementation
Hi Sheng, I've implemented a simple module which instantiates the LPM_DIVIDER only and a process that feeds the divider with 1000 couples of operands. As I expected, I've seen the same strange behavior of the implemented module which is different from the simulation when the quotient is negative. The following figure show this difference:
I've taken into consideration only the first division of the sequence, since the problem is the same also in the subsequent divisions. Operands:
Numerator = FFFFFFEC82000000h = -83718307840d; Denominator = 000000000Bh = 11d.
Quotient (SignalTap) = FFFFFFFE3A5D1745h = -7610755259d; Remainder (SignalTap) = 0000000009h = 9d.
Quotient (Simulation) = FFFFFFFE3A5D1746h = -7610755258d; Remainder (Simulation) = 7FFFFFFFFEh = -2d.
If can be of some help, I've implemented the module on a ARRIA10 FPGA (10AX066K4F35I3SG) using the following version of Quartus Prime: Quartus Prime Version 20.1.1 Build 720 11/11/2020 Patches 1.02std SJ Standard Edition.
Thank you,
Marco
