LPM DIVIDE behaves differently between simulation and implementation
Understood that. Please let me know whether simple one only with the divider and an operands generator inside got same simulation and signal tap?
Sheng
Hi Sheng,
I've implemented this simple selfchecking module, which instantiates only the LPM_DIVIDE, stimulated with 1000 couple of operands. I've simulated the module, synthesized and checked its behavior with SignalTap. As I though, the strange behaviour previously observed is present also in this version:
Considering the first operation:
Operands:
Numerator = FFFFFFEC82000000h = -83718307840d
Denominator = 000000000Bh = 11d.
The result is -83718307840/11 = -7610755258.181818 or -7610755258 with a remainder of -2, that are the outputs provided by the module during the simulation: Quotient: FFFFFFFE3A5D1746h and Remainder: 7FFFFFFFFEh
On the other side, the implemented divider publishes these results:
Quotient: FFFFFFFE3A5D1745h and remainder of 0000000009h, which are different from the one seen during simulation.
I've tested the module using Quartus Prime Version 20.1.1 Build 720 11/11/2020 Patches 1.02std SJ Standard Edition implementing it on a Arria 10 10AX066K4F35I3SG.
