11 years ago
looping over a string character by character in Verilog
I'm attempting to send a string character by character over a serial port. I have the serial port down, but I don't quite see how to implement a changing index on a string...
Ideally, my module would take as input a clock counter (synced to the baud rate of my serial module), and based on that clock input send out a character.
Here's what I have so far, which works, but it seems like there is a much better way of doing it.
module sendString(
    input wire  clockInput,
    output  TxD_start,
    output  TxD_buffer
reg  message = "Help! I'm trapped in an FPGA!";
reg  tmpbuffer;
always @*
begin
    if(clockInput==5'b00000)
    begin
        tmpbuffer <= message;
    end
    if(clockInput==5'b00001)
    begin
    end
    //and so on, for the other clock cases
end
assign TxD_buffer = tmpbuffer;
assign TxD_start = 1;
endmodule
1 Reply
    You may start defining your message array like this:
    reg [7:0] message [29:0]
    Then you can use simple indexing to access each character.
    Moreover I would recommend using a clock and synchronous logic.
    Infact, always @* implies a purely combinatorial behaviour: this is usually not recommended, especially in your case which is basically a clock-driven process.
