Your fastest method would be to build your own DMA controller to read/write directly to the SDRAM. However, that's a significant effort. So the next best would be to use the SGDMA controllers and use Avalon-ST interfaces to get the data to/from the SGDMA controller.
A simple example is the Triple-speed ethernet reference design. Jake - Altera_Forum
Thank you for your help. I will look into it.
Best regards, Sean Nguyen - Altera_Forum
I am using the sdram controller that comes with SOPC builder. You can achieve 98%+ throughput to the SDRAM if you connect your own MM master to it. On a speed grade 8 CIII I can meet timing running at 80Mhz easily.
I can put out some example VHDL (don't know verilog) if you need help doing a MM master component that reads and writes to the SDRAM controller. - Altera_Forum
The avalon MM interface is as fast as the clock you are driving your components with. And you have a variable data port width.
I use an 80Mhz clock on my components and am using a 16bit data port SDRAM. So I can achieve close to 160MB/s to the SDRAM.
