Altera_ForumHonored Contributor15 years agoLook for the best fastest way Avalon streaming Hi there, I'm looking for the best fastest way of Avalon stream (Avalon-MM/ST, Source/Sink), because I need fast streaming of SDR data). Does anybody have a simple sample like megacore FFT/FI...Show More
Altera_ForumHonored Contributor15 years agoThank you for your help. I will look into it. Best regards, Sean Nguyen
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
