15 years agoI am using the sdram controller that comes with SOPC builder. You can achieve 98%+ throughput to the SDRAM if you connect your own MM master to it. On a speed grade 8 CIII I can meet timing running at 80Mhz easily.
I can put out some example VHDL (don't know verilog) if you need help doing a MM master component that reads and writes to the SDRAM controller.
