14 years ago
Logic gate output from bus
Hello to everybody,
I hope I am posting this at the right place.
My question is actually very simple. I have a bus, e.g. a[3..0]. And I want to make an OR gate with one output which makes ORs for all nodes in the bus, i.e. (a[3] OR a[2] OR a[1] OR a[0]).
In particular, I am looking for an symbol/component. I think there has to be a simple solution, but the primitive OR gate does not accept buses. The lpm_or gate would rather make an OR gate on two or more buses, but not on the nodes of one bus.
And since this question is also related, is there a function in AHDL or VHDL there for, for example OR(a[]).
Thank you in advance!
    for a symbol, you may need to separate out each bit individually and input it into the gate. You can do this by named association
    Forget about AHDL (its a dead language)
    in VHDL, you can simply use one of the two methods:
    library ieee;
    use ieee.std_logic_1164.all; --library used everywhere
    use ieee.std_logic_misc.all; --has some useful reduction operations
    signal a : std_logic_vector(7 downto 0);
    signal b : std_logic;
    b <= or_reduce(a); --also, and, nand, nor, xor, xnor reduce functions
    or when Altera finally add some decent VHDL 2008 support:
    b <= or a;
    Yeah, thanks. In the last time I studied a bit VHDL and that's exactly I was looking for.
