OHarb1
6 years agoLocate Design File does not work on a restored project from a .qar file in TimeQuest
When I restore a .qar file that has been generated in by our build in the cloud, I can't use Locate Design File from Timequest. The problem is that the .qar file contains absolute paths, which exist...
sstrell
6 years agoNormally, when you archive a project that includes files outside the project directory, the archiver copies the external files into the .qar and gives them a virtual drive letter to make the .qar portable. I don't know if the -common_dir option (which I haven't seen before) is affecting this. Have you tried creating the .qar without this option?
#iwork4intel
OHarb1
6 years agoExcluding "-common_dir", has no effect: Quartus still tries to use absolute paths on the restored project and TimeQuest fails to locate the design file.
The absolute path is to a folder within the folder where top.qsf is located.
