I don think you need to use the jtagconfig command. All you need to do is install the config file and point the jtag binary to it. As long as you follow the instructions above, you should be good.
Can you send details of what you are doing, what distribution, and step by step account of how you are getting to the error?. - Altera_Forum
jtagconfig is a useful command for testing that you have everything set up correctly so I would certainly do that at the end (and be worried if it does not work).
The official instructions are on http://www.altera.com/download/drivers/dri-usb_b-lnx.html - these should work if you are only using the USB-Blaster cable from the machine it is plugged in to.
