14 years agojtagconfig is a useful command for testing that you have everything set up correctly so I would certainly do that at the end (and be worried if it does not work).
The official instructions are on http://www.altera.com/download/drivers/dri-usb_b-lnx.html - these should work if you are only using the USB-Blaster cable from the machine it is plugged in to.
