Giorgi_Kvernadze
10 months agoLicesnse for Questa?
I downloaded the free, lite version of Quartus Prime and opted for installing Questa, during the installation setup. But now when I try to run it, it doesn't work. Is a separate license for Que...
- 10 months ago
Hmm, it looks like almost everything is correct.
Could you double-check if the NIC ID is correct?
Also this is a Fixed type license, correct?
5.5.1. Identifying Host's NIC ID
Richard Tan
ShengN_altera
10 months agoHi,
You need separate license check screenshot:
Giorgi_Kvernadze
10 months agoI did that, but nothing changed.
When trying to launch Questa manually I just get this pop up and it goes away, with nothing happening afterwards.
And when I set up Quartus to run the simulation automatically after compilation, I get the following messages:
- ShengN_altera10 months ago
Latest version simulator needs environment variable SALT_LICENSE_SERVER for fixed license
- Giorgi_Kvernadze10 months ago
I have added the fixed license, as SALT_LICENSE_SERVER environment variable
May I know you're using company working environment like vnc or virtual machine?
