marie_toutain
2 years agoLicensing for quartus Prime Lite 17.0.2
Hello, I'm using Quartus Prime Lite 17.0.2 on linux using command line. When I want to compile (quartus_sh --flow compile project.qpf ) I receive the following error: Error (292025): License fil...
marie_toutain
2 years agoHello,
Thank you for your answer.
However, I'm always blocked by the license .
When I run global request and the compilation isn't sucessful: I obtain the following result and there is no output folder, the top_upp_amp.rbf is missing
intelFPGA_lite_adress/17.0/quartus/bin/quartus_sh --flow compile file_qpf_address/top_upp_amp.qpf Info: ******************************************************************* Info: Running Quartus Prime Shell Info: Version 17.0.0 Build 595 04/25/2017 SJ Standard Edition Info: Copyright (C) 2017 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Intel and sold by Intel or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Mon Dec 18 10:03:16 2023 Info: Command: quartus_sh --flow compile file_qpf_address/top_upp_amp.qpf Info: Quartus(args): compile file_qpf_address/top_upp_amp.qpf Info: Project Name = file_qpf_address/top_upp_amp Info: Revision Name = top_upp_amp Error (292025): License file is not specified. Error (293001): Quartus Prime Full Compilation was unsuccessful. 1 error, 0 warnings Error: Flow compile (for project file_qpf_address/top_upp_amp) was not successful Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last. Error (23031): Evaluation of Tcl script intelFPGA_lite_adress/17.0/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 5 errors, 0 warnings Error: Peak virtual memory: 773 megabytes Error: Processing ended: Mon Dec 18 10:03:18 2023 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:01
Then I try running each step request but the result is the same : there is no output folder, the top_upp_amp.rbf is missing:
intelFPGA_lite_adress/17.0/quartus/bin/quartus_map --read_settings_files=on --write_settings_files=off file_qpf_address/top_upp_amp.qpf -c file_qpf_address/top_upp_amp.qpf Error (292025): License file is not specified.
intelFPGA_lite_adress/17.0/quartus/bin/quartus_fit --read_settings_files=off --write_settings_files=off file_qpf_address/top_upp_amp.qpf -c file_qpf_address/top_upp_amp.qpf Info: ******************************************************************* Info: Running Quartus Prime Fitter Info: Version 17.0.0 Build 595 04/25/2017 SJ Standard Edition Info: Copyright (C) 2017 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Intel and sold by Intel or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Mon Dec 18 10:29:17 2023 Info: Command: quartus_fit --read_settings_files=off --write_settings_files=off file_qpf_address/top_upp_amp.qpf -c file_qpf_address/top_upp_amp.qpf Info: qfit2_default_script.tcl version: #1 Info: Project = top_upp_amp Info: Revision = top_upp_amp Error (11720): Run Analysis and Synthesis (quartus_map) with top-level entity name "top_upp_amp" before running Fitter (quartus_fit) Error: Quartus Prime Fitter was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 802 megabytes Error: Processing ended: Mon Dec 18 10:29:17 2023 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:00
quartus_map is running juste before this command but was blocked by the license problem.
intelFPGA_lite_adress/17.0/quartus/bin/quartus_asm --read_settings_files=off --write_settings_files=off file_qpf_address/top_upp_amp.qpf -c file_qpf_address/top_upp_amp.qpf Error (292025): License file is not specified.
intelFPGA_lite_adress/17.0/quartus/bin/quartus_pow --read_settings_files=off --write_settings_files=off file_qpf_address/top_upp_amp.qpf -c file_qpf_address/top_upp_amp.qpf Error (292025): License file is not specified.
intelFPGA_lite_adress/17.0/quartus/bin/quartus_sta file_qpf_address/top_upp_amp.qpf -c file_qpf_address/top_upp_amp.qpf Error (316008): Selected feature of TimeQuest Timing Analyzer is not available with your current license, or license does not exist
intelFPGA_lite_adress/17.0/quartus/bin/quartus_eda --read_settings_files=on --write_settings_files=off file_qpf_address/top_upp_amp.qpf -c file_qpf_address/top_upp_amp.qpf Error (292025): License file is not specified.
At the end of all these commands there is no output folder or rbf file.
Do you know how I can resolve this problem?
