15 years agoLicense question
I have a question about the license,
how can I check which FPGA families are supported by the license file that I have currently in use? ThanksI have a question about the license,
how can I check which FPGA families are supported by the license file that I have currently in use? Thanksin general, supported devices aren't called out in the license file. Quartus II Web Edition only has support for limited families while Subscription Edition supports all families:
http://www.altera.com/literature/po/ss_quartussevswe.pdf there are some rare exceptions of older devices or families that require a separate license entry but i can't remember specificsi saw your other thread, there shouldn't be any problems targeting Cyclone II
which IP are you using that require a license?if you attach a small example project i can take a look
