Altera_ForumHonored Contributor15 years agoLicense question I have a question about the license, how can I check which FPGA families are supported by the license file that I have currently in use? Thanks
Altera_ForumHonored Contributor15 years ago --- Quote Start --- if you attach a small example project i can take a look --- Quote End --- Do you mean the .mdl file or all the files after the simulation?
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
