Library naming issue with "add_hdl_instance"
My static IP component needs a floating point "multiply and add". So I added an altera_fp_functions instance via "add_hdl_instance" in the elaboration function of my IP's TCL file.
That works fine so far. However, Platform Designer puts the component into a library with a generated name, which is based on the system's hierarchy (something like "top_myip_mymultiplyadd").
Of course, my IP component's VHDL code must be generic. It must not depend on any system hierarchy.
Is there a way to force Platform Designer to use a static library name?
- RichardT_altera
Sorry for the late reply. Could you refer to the document link on 2.10.1. Static IP Components - Typical Usage of the add_hdl_instance Command for Static Components?
Check that you have followed the correct usage of the add_hdl_instance for static components.
Let me know if it helps to solve the issue.Best Regards,
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- c-thaler
Thanks for the reply. I solved the issue in the meantime. But I did not follow the document you referred to.
I added a Verilog wrapper file for the generated floating point instance, since Verilog does not have the concept of libraries. Then I added the wrapper file to qip into the same library my component uses. After that, I was able to successfully instantiate the Verilog wrapper from my component's source code. I did not use autogenerated names, so it worked without any regex substitutions to the original source code.
- RichardT_altera
Good to know that you are able to found the solution. This will be helpful to those who may come across similar issue.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
- JHill1
I had a quick look at what is being suggested as the TCL orchestrated solution above, see below.
All I can say is that configuring IP with VHDL generics just might be a simpler and less kludgy way to integrate Intel/Altera generated IP into HDL?
proc generate { entity_name } {
# get the autogenerated name for emif_instance_name added
# via add_hdl_instance
set autogeneratedfixedname [get_instance_property \
emif_instance_name HDLINSTANCE_GET_GENERATED_NAME]
set fileID [open "generated_toplevel_component.v" r]
set temp ""
# read the contents of the file
while {[eof $fileID] != 1} {
gets $fileID lineInfo
# replace the top level entity name with the name provided
# during generation
regsub -all "substitute_entity_name_here" $lineInfo \"${entity_name}" lineInfo
# replace the autogenerated name for emif_instance_name added
regsub -all "substitute_autogenerated_emifinstancename_here" \
$lineInfo"${autogeneratedfixedname}" lineInfo \
append temp "${lineInfo}\n"
