Library naming issue with "add_hdl_instance"
Sorry for the late reply. Could you refer to the document link on 2.10.1. Static IP Components - Typical Usage of the add_hdl_instance Command for Static Components?
Check that you have followed the correct usage of the add_hdl_instance for static components.
Let me know if it helps to solve the issue.
Richard Tan
Thanks for the reply. I solved the issue in the meantime. But I did not follow the document you referred to.
I added a Verilog wrapper file for the generated floating point instance, since Verilog does not have the concept of libraries. Then I added the wrapper file to qip into the same library my component uses. After that, I was able to successfully instantiate the Verilog wrapper from my component's source code. I did not use autogenerated names, so it worked without any regex substitutions to the original source code.
- RichardT_altera5 years ago
Good to know that you are able to found the solution. This will be helpful to those who may come across similar issue.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
