9 years ago
LFSR doesn't generate random values during simulation Ask
I am new to VHDL. I made this LFSR but don't know why it is stuck between the initial seed value and the other XOR value. I am working with Altera Quartus 16 Lite and ISim.
Here is the link https://stackoverflow.com/questions/45486770/lfsr-doesnt-generate-random-values-during-simulation?noredirect=1#comment77935100_45486770 to the original question as I cannot post the code and problem in here as it exceeds the allowed character length.
    For a start, most of the bus is just assigned to itself, hence the no changing:
    Each set of bits:
    [15:11] : assigned to itself
    [10] toggles, as you just xor it with the LSB
    [9:5] assigned to itself
    [4] toggles, as just xored with LSB
    [3:0] assigned to itself.
    So this will explain what you are seeing.
    & is the concatenate operator in VHDL, not and.
    PS. I dont think you mean ISIM, the picture you show is modelsim. ISIM is XIlinx simulation tool.
    --- Quote Start ---
    --- Quote End ---
    Here is example of 20 bit LFSR(20 downto1):
    --clocked process and iitial seed of nonzero
    shiftreg(1) <= shiftreg(17) xor shiftreg(20);
    shiftreg(20 downto 2) <= shiftreg(19 downto 1);
    yes but it is for Fibonacci LFSR not Galois.
    Thanks for reply.
    Thanks a lot guys I found why it was not shifting. Here is the working part.
    temp_out(15) <= temp_out(0);-- shifting bit
    temp_out(14) <= temp_out(15);
    temp_out(13) <= temp_out(14) xor temp_out(0);
    temp_out(12) <= temp_out(13) xor temp_out(0);
    temp_out(11) <= temp_out(12);
    temp_out(10) <= temp_out(11) xor temp_out(0);
    temp_out(9 downto 0) <= temp_out(10 downto 1);
    --- Quote Start ---
    Yes you are right, its ModelSim
    --- Quote End ---
    My example is Fibanocci for your case of 16 bits
    shiftreg(1) <= shiftreg(16) xor shiftreg(15) xor shiftreg(13) xor shiftreg(4); --feeback taps
    shiftreg(16 downto 2) <= shiftreg(15 downto 1); -- shift
