jtag not working with Arria 10 GX FPGA Dev Kit
We have an Arria 10 GX Dev Kit that we've been using for a couple years and it was working fine (Ubuntu 16.04, Intel FPGA SDK for OpenCL 18.0). The other day, I updated the Intel FPGA SDK to version 19.1 (I now have both versions installed, but all my paths point to version 19.1). Ever since I did that, the usb blaster stopped working. When I first plug the FPGA into the usb port, I can see it in "lsusb" as the following:
Bus 002 Device 005: ID 09fb:6810 Altera And "dmesg | tail" gives the following output:
[ 183.109435] usb 2-1.7: new high-speed USB device number 5 using ehci-pci
[ 183.217853] usb 2-1.7: New USB device found, idVendor=09fb, idProduct=6810
[ 183.217856] usb 2-1.7: New USB device strings: Mfr=0, Product=0, SerialNumber=0Next, when I run jtagconfig, it first shows "connecting to servers [...]' but then it displays the message " No jtag hardware available", and running "dmessage|tail" now shows
[ 294.061479] usb 2-1.7: USB disconnect, device number 5
[ 295.598535] usb 2-1.7: new high-speed USB device number 6 using ehci-pci
[ 300.838369] usb 2-1.7: device descriptor read/64, error -110Any ideas what the issue might be?
Welcome to INTEL forum. Yes, there are some issue regarding USB-Blaster II use in Quartus 19.1 and engineering come out with Patch 0.03 as a worked-out solution refer here
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-my-usb-blaster-ii-not-work-when-using-intel--quartus---.html
- AR_A_Intel
- aejjeh
This worked. Thanks!
