11 years agojk flip flop usin dataflow model
How to design jk flip flop using dataflow model.
When i run the code it shows an error "iteration limit reached". my vhdl code is library ieee; use ieee.std_logic_1164.all; ------------------------------------------------------------- entity jkff_dataflow is port(j,k,clk,rst:in std_logic; q,qbar:inout std_logic); end jkff_dataflow; ------------------------------------------------------------- architecture jkff_dataflow of jkff_dataflow is begin q<=(((k and clk) and qbar) nor qbar) nor rst; qbar<=((j and clk) and q) nor q; end jkff_dataflow;4 Replies
You hehe created a logic loop. Q depends on qbar, and q bar depends on q, so it gets in an infinite loop. Q and q bat styles not be linked.
Also, you should be using the clk signal as a clock, bout a logic signal. - Altera_Forum
--- Quote Start --- You hehe created a logic loop. Q depends on qbar, and q bar depends on q, so it gets in an infinite loop. Q and q bat styles not be linked. Also, you should be using the clk signal as a clock, bout a logic signal. --- Quote End --- so to design jk flip flop I need to use behaviour modeling. so I cannot write code by using data flow model. - Altera_Forum
In don't know what this data flow model is you're talking about. Vhdl describes a logic circuit, hence it can only be a behaviour. Your code just describes a logic loop.
--- Quote Start --- so to design jk flip flop I need to use behaviour modeling. so I cannot write code by using data flow model. --- Quote End --- A data flow model is a higher-level construct. A JK flip-flop is just an implementation detail.
