11 years agojk flip flop usin dataflow model
How to design jk flip flop using dataflow model. When i run the code it shows an error "iteration limit reached". my vhdl code is library ieee; use ieee.std_logic_1164.all; -----...
11 years agoYou hehe created a logic loop. Q depends on qbar, and q bar depends on q, so it gets in an infinite loop. Q and q bat styles not be linked.
Also, you should be using the clk signal as a clock, bout a logic signal.
