Issues debugging DDR3 controller using SignalTap on Quartus Prime Standard 23.1 with Arria V GZ FPGA
- 1 year ago
In this situation, it doesn't matter, it's the same signal no matter what.
Using pre-synth vs. post-fit comes more into play if you're trying to reduce recompile times (short ECO compilation with post-fit vs. full recomp with pre-synth even though in Standard edition, that isn't really a big thing either unless you are using incremental compilation).
Short answer for you: it doesn't really matter.
Can you clarify better what signals you can and cannot see? You say you "see the ones driven by the logic", but you can't see "the signals coming from the IP"? It's not clear what you mean by this. Like you can see the address bits (signals from logic to IP) but not readdata from the IP?
If you are talking about the memory signals that go out to the external memory, you can't tap those signals assuming you are using the hard controller.
