Issue with RTL library compilation for simulation in OpenCL
I am getting the following error message on compiling RTL library for simulation in OpenCL version 18.1-
aoc: First stage compilation completed successfully.
Compiling for Simulator.
Creating simulation system...
Generating simulation system...
Compiling simulation...
Error: Simulation compile FAILED.
Refer to test/test.log for details.
However there is no test log created.
How do I debug this error?
- MEIYAN_L_Intel
May I know do you have done the step according to the https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf in chapter 10.1.8.1?
Also, may I know the information as below:
- OS used
- OpenCL SDK Edition
- VE000
Hi
Thanks for the reply
Yes. Have followed all the steps mentioned in Chapter 10.1.8.1.
OS Used : Ubuntu 18.04
OpenCL SDK Edition : 18.1 Pro
- MEIYAN_L_Intel
Could you give the full error message for further investigation?
Also, could you try to run compilation and simulation for example 1 as in Chapter 10.1.9 by follow the instruction in README.html?
Soft reminder: https://fpgasoftware.intel.com/requirements/18.1/, the OpenCL SDK v18.1 is not officially supported in Ubuntu 18.04.
- VE000
Hi
The error is not generated. Only these lines are present as an error message.
There are no instructions for simulation of the example 1 in the 'readme.html' file. I am able to successfully compile and EMULATE the example.
- MEIYAN_L_Intel
I had reviewed to the README.html, there is stated as below:
To use the simulation flow, the compilation command just needs to be modified slightly:
aoc -march=simulator device/example1.cl -o bin/example1.aocx -I device/lib1 -L device -l opencl_lib.aoclib -board=<board>
Could you try to run the simulator for this example 1?
- VE000
Hi
Will check that.
I am giving "a10gx" reference board as the name of the board. Is that OK?
- MEIYAN_L_Intel
Yes, the device name is a10gx.
If the example 1 can be simulate without error, could you try to used these command to run simulation to your design?
- VE000
HI
On running the example1 based on the instructions in readme.html and chapter 10.1.8.1
Am now getting this error message -
ERROR: No devices found
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 18.1
Querying device for info:
CL_DEVICE_NAME =
CL_DEVICE_VENDOR =
CL_DEVICE_VENDOR_ID = 32517
Segmentation fault (core dumped)
I have unset the Emulation environment variable - CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA. However the error persists.
- MEIYAN_L_Intel
According https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf in chapter 10.1.8.2, do you have set the CL_CONTEXT_COMPILER_MODE_INTELFPGA=3 for the host program to find the simulator device?
- VE000
Hi
Yes, I had set the CL_CONTEXT_COMPILER_MODE_INTELFPGA=3 but got that error
- MEIYAN_L_Intel
May I know the environment variables that you had set?
Also, may I know the when building RTL library, do the RTL files and other files specified in XML specification file contain charaters other than lower case letters, numbers, periods, underscores and slashes?
