VE000
6 years agoIssue with RTL library compilation for simulation in OpenCL
I am getting the following error message on compiling RTL library for simulation in OpenCL version 18.1- aoc: First stage compilation completed successfully. Compiling for Simulator. Creating simu...
MEIYAN_L_Intel
6 years agoHi,
I had reviewed to the README.html, there is stated as below:
To use the simulation flow, the compilation command just needs to be modified slightly:
aoc -march=simulator device/example1.cl -o bin/example1.aocx -I device/lib1 -L device -l opencl_lib.aoclib -board=<board>
Could you try to run the simulator for this example 1?
VE000
6 years agoHi
Thanks for the reply
Will check that.
I am giving "a10gx" reference board as the name of the board. Is that OK?
