Issue with RTL library compilation for simulation in OpenCL
Yes, the device name is a10gx.
If the example 1 can be simulate without error, could you try to used these command to run simulation to your design?
HI
Thanks for the reply
On running the example1 based on the instructions in readme.html and chapter 10.1.8.1
Am now getting this error message -
ERROR: No devices found
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 18.1
Querying device for info:
CL_DEVICE_NAME =
CL_DEVICE_VENDOR =
CL_DEVICE_VENDOR_ID = 32517
Segmentation fault (core dumped)
I have unset the Emulation environment variable - CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA. However the error persists.
