VE000
6 years agoIssue with RTL library compilation for simulation in OpenCL
I am getting the following error message on compiling RTL library for simulation in OpenCL version 18.1- aoc: First stage compilation completed successfully. Compiling for Simulator. Creating simu...
MEIYAN_L_Intel
6 years agoHi,
Could you give the full error message for further investigation?
Also, could you try to run compilation and simulation for example 1 as in Chapter 10.1.9 by follow the instruction in README.html?
Soft reminder: https://fpgasoftware.intel.com/requirements/18.1/, the OpenCL SDK v18.1 is not officially supported in Ubuntu 18.04.
- VE0006 years ago
Hi
The error is not generated. Only these lines are present as an error message.
There are no instructions for simulation of the example 1 in the 'readme.html' file. I am able to successfully compile and EMULATE the example.
