JDlug
6 years agoIssue with Quartus Prime PRO for Stratix 10 when using a string type in a VHDL project.
Hello, When using "Quartus Prime Pro 20.1" software with "Stratix 10" chip, I have a problem with VHDL string type in my projects. At the same time, I don't have this problem when using "Quartus Pri...
KhaiChein_Y_Intel
6 years agoHi JD,
I understand that the "ENABLE_STATE_MACHINE_INFERENCE OFF"
assignment helped in the simple code attached in this forum post. The Internal Error window does not appear in the simple code but this setting did not help in the real projects.
Could you share the file that you see the error after applying the setting?
KhaiY
JDlug
6 years agoHi KhaiY,
These errors appeared in my large project. Give me some time and I'll
try to prepare a small example that will show the same mistakes. I'll
put it here when I'm ready. Thank you.
(jd)
