--- Quote Start --- i have a problem installing Quartus-web-13.0.1.232 on my win7 64 bit every time I'm trying to install it I'm getting a msg that "Quartus-web-13.0.1.232 has stopped working" and the options are to debug or stop the process. the install files are good because they work on my xp mode virtual machine. please help ! --- Quote End --- Yes, my machine is a 64-bit one and runs on windows 7 too. I have experienced the same issue and I could use immediate help. What is more interesting is I also installed web edition on XP and it worked quite well. - Altera_Forum
--- Quote Start --- Yes, my machine is a 64-bit one and runs on windows 7 too. I have experienced the same issue and I could use immediate help. What is more interesting is I also installed web edition on XP and it worked quite well. --- Quote End --- same here : ) on my virtual machine it installed fine try installing it on win7 on safe mode it worked for me. - Altera_Forum
Thank you :) I did just as you said. It worked. Thanks a lot!
