PiyushM
1 year agoIssue in Quartus 16.1 with Windows 11 Pro
IssueHi, I am using Quartus Prime 16.1 Standard Edition and utilize schematic entry to create .bdf file. OS is Windows 11 Pro. I am facing issue to view 1) Block & Symbol names 2) Instance, ...
- 1 year ago
As mentioned, version 16.1 is not supported in Window 11.
Sheng
ShengN_altera
1 year agoHi,
Sheng
- PiyushM1 year ago
Hi ShengN,
Thanks for reply.
We will downgrade OS to Window 10. It is the Final Solution.
- PiyushM1 year ago
I changed the Display scaling to custom value 110% and all display related problem is solved.
- DrRussMeierMSOE1 year ago
@PiyushM :
Exactly. The standard response on these forums is "its not compatible." Sorry for your frustrations but you have nailed the solution.- Windows 11 recognizes very high definition displays at installation and may default the display scale to 150 or 200% to make text easier to read. While this works well in many applications. Quartus isn't auto-scaling based on the display settings. This makes the display text push into the symbol.
- I have my students display at 100% while they are working in Quartus. This fixes all of the text issues. When they are done using Quartus, they can then rescale display settings if desired.
