SamGilligan
2 years agoIssue converting programming files for the Stratix10GX Dev Kit
I'm currently working with the Stratix10GX Dev Kit using Quartus Pro 21.4 To program test images to flash, the images are first converted using the provided build_hw.sh through the Nios II Command S...
Ash_R_Altera
2 years agoMay I also know why you say "Stratix10GX is not supported through Convert Programming File.". Any document you referred, that mentions this?
SamGilligan
2 years agoIt seems to be printed out in response to using the script, and also appears if you attempt to add the sof file inside the Convert Programming Files GUI.
The error message is:
"Error(20687): Convert Programming Files does not support the target device 1sg280hu2f50e2vg. Please use Programming File Generator to generate the programming file for the target device."
