SamGilligan
2 years agoIssue converting programming files for the Stratix10GX Dev Kit
I'm currently working with the Stratix10GX Dev Kit using Quartus Pro 21.4 To program test images to flash, the images are first converted using the provided build_hw.sh through the Nios II Command S...
sstrell
2 years agoCan't you just use the Programming File Generator directly? Why do you need to use that script?
