Is there any reason why the actual behavior in this symbol is different from the schematic?
I understand that the waveform issue has been resolved.
I tried to create a LPM_COUNTER, the maximum width supported is 256. You mentioned that the LPM-COUNTER IP does not work and it is limited to 8 bits. May I know what error you see? Is it a compilation error? Could you share the error message and steps to reproduce the error?
KhaiY
- OJin06 years ago
The error message could not be saved at the time the error occurred.
Reproducing it today, it is working fine.
At that time, there was no waveform of all output bits.
In the current project, everything is operating normally, so it seems that the past state cannot be reproduced.
So, I am checking with the new project "ElectricPiano_00_00", but the problem is also confirmed in this project.
Thank you.
