8 years agoIs there an Editor in Platform Designer?
If I wanted to edit/create some custom IP, that is going to be included in a Qsys-project, is there any way to edit the VHDL of a file from within Platform Designer?
I know I can define the wrapper with its ports/conduits etc, but to actually add more VHDL inside, I currently need to use a 3rd party text editor. The irony is that if you open the file (post synthesis) from the Quartus Project navigator, you get the copied-version in the ../project_name/submodules/ folder...why?4 Replies
1.Why can't you write a logic and then create a custom IP? --- Quote Start --- is there any way to edit the VHDL of a file from within Platform Designer? --- Quote End --- No, can't edit/add the logic by using platform designer for the custom component. --- Quote Start --- I know I can define the wrapper with its ports/conduits etc, but to actually add more VHDL inside, I currently need to use a 3rd party text editor --- Quote End --- Why use 3rd party either you can use Quartus itself. You first create a wrapper and then add logic and compile the design and use it. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
I use a 3rd party editor because I can set my editor to always look for my files in their source directory.
If you use the Project Navigator to open a file, Quartus opens the copied version of the file, not the source. Is there a way to change this? Thanks. - Altera_Forum
Have you set Preferred Text Editor in Quartus? Form tools->options->Preferred Text Editor. Select text editor of you choice and command-line point to .exe file. If still quartus opens copied version of the file check the text editor settings. I have used Notepad++ and opened the file from quartus it opens the source file only. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
If you go to the Files tab of the Project Navigator, instead of the Hierarchy tab, you can double-click a source file to open and edit it.
However, for a custom component in Platform Designer, what you're seeing in the Project Navigator is the generated output of Platform Designer since you added this as a custom component to a system. That's why the original source file is not opening from the Project Navigator; Quartus sees the generated output, which is a copy of the original. The only sure way to open the source for editing is to do File -> Open. You'll still have to regenerate the _hw.tcl file and the system anyway.
