8 years agoIs there an Editor in Platform Designer?
If I wanted to edit/create some custom IP, that is going to be included in a Qsys-project, is there any way to edit the VHDL of a file from within Platform Designer? I know I can define the wrappe...
8 years agoHi,
Have you set Preferred Text Editor in Quartus? Form tools->options->Preferred Text Editor. Select text editor of you choice and command-line point to .exe file. If still quartus opens copied version of the file check the text editor settings. I have used Notepad++ and opened the file from quartus it opens the source file only. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
