8 years agoIs there an Editor in Platform Designer?
If I wanted to edit/create some custom IP, that is going to be included in a Qsys-project, is there any way to edit the VHDL of a file from within Platform Designer? I know I can define the wrappe...
8 years agoHi,
1.Why can't you write a logic and then create a custom IP? --- Quote Start --- is there any way to edit the VHDL of a file from within Platform Designer? --- Quote End --- No, can't edit/add the logic by using platform designer for the custom component. --- Quote Start --- I know I can define the wrapper with its ports/conduits etc, but to actually add more VHDL inside, I currently need to use a 3rd party text editor --- Quote End --- Why use 3rd party either you can use Quartus itself. You first create a wrapper and then add logic and compile the design and use it. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
