8 years agoIs there an Editor in Platform Designer?
If I wanted to edit/create some custom IP, that is going to be included in a Qsys-project, is there any way to edit the VHDL of a file from within Platform Designer? I know I can define the wrappe...
8 years agoIf you go to the Files tab of the Project Navigator, instead of the Hierarchy tab, you can double-click a source file to open and edit it.
However, for a custom component in Platform Designer, what you're seeing in the Project Navigator is the generated output of Platform Designer since you added this as a custom component to a system. That's why the original source file is not opening from the Project Navigator; Quartus sees the generated output, which is a copy of the original. The only sure way to open the source for editing is to do File -> Open. You'll still have to regenerate the _hw.tcl file and the system anyway.
