sam135
2 years agoIs there a problem with executing Questa FSE using WSL?
I have trouble using Questa FSE.
It seems that installation and license registration are ok, because i can run the questiona for a while.(i can see Questa GUI for a while)
However, the Questa ends immediately saying that there is no viewer license.
I tried to use linux version Questa FSE using WSL2 on Windows 11. Will this be a problem?
or, is there anything else i can check?
below is the terminal log when i run questa.
./vsim
Reading pref.tcl
Unable to checkout a viewer license necessary for use of the Questa Intel Starter FPGA Edition graphical user interface. Vsim is closing.
- sam135
There was a problem with the license because the mac address in the WSL is not static.I solved the problem by adding some script to the bashrc.for example,```wantmac=[mac address you need]mac=$(ip link show bond0 | awk '/ether/ {print $2}')if [[ $mac != $wantmac ]]; thensudo ip link add name bond0 type bond mode active-backupsudo ip link set dev bond0 address $wantmacfiexport LM_LICENSE_FILE=/mnt/e/License/[License file path]:$LM_LICENSE_FILE```I referred to the post below. - SyafieqS
Glad that you have resolved the issue. I am putting this to close pending
