JWall40
6 years agoIs it possible to simulate the FFT IP core inside Quartus
I'm trying to use the University Program VWF to simulate a simple implementation of the FFT IP core. However, when I attempt to run the simulation I get the following errors relating to the sub-modu...
CheepinC_altera
6 years agoHi,
For your information, I have emailed you a ZIP of the Q17.0 CV FFT IP generated design. You may try with the following to run the simulation:
1. Unzip the files
2. In Modelsim, change directory to the \simulation_scripts\mentor
3. Type "source msim_setup.tcl"
4. Type "ld"
5. Type "do wave.do"
6. Type "run -all"
7. When message pops up asking if you want to finish the simulation, click "No"
You should be able to see the example simulation waveform. In case you still encounter any file cannot be found error, you might want to reduce the level of hierarchy is putting the ZIP at C: driver.
