JWall40
6 years agoIs it possible to simulate the FFT IP core inside Quartus
I'm trying to use the University Program VWF to simulate a simple implementation of the FFT IP core. However, when I attempt to run the simulation I get the following errors relating to the sub-modu...
CheepinC_altera
6 years agoHi,
For your information, I am referring to typing "source msim_setup.tcl" command into Modelsim. this will setup the simulation environment as in the TCL file. Only after this, you can run the "ld" command.
