JWall40
6 years agoIs it possible to simulate the FFT IP core inside Quartus
I'm trying to use the University Program VWF to simulate a simple implementation of the FFT IP core. However, when I attempt to run the simulation I get the following errors relating to the sub-modu...
CheepinC_altera
6 years agoHi,
As I understand it, you have some inquiries related to simulating the FFT IP. For your information, generally we would use the Modelsim Intel FPGA Edition to perform the functional simulation of the FFT. You try to perform the simulation through the following:
1. Open FFT IP
2. Go to Generate -> Generate Example Design
3. Open Modelsim and change directory to the fft_ii_0_example_design\simulation_scripts\mentor
4. source the msim_setup.tcl
5. type "ld" to run the compilation
6. Populate the waveforms and then type "run -all"
Chee Pin
- JWall406 years ago
Please could you elaborate on step 4. source the msim_setup.tcl
What do you mean by 'source' it and how can I do this?
Thank you very much!
