MEnan
6 years agoIs it possible to build a Programmer Object File(.pof) using a time limited SRAM object file(.sof)
I am trying out a Max10 Evaluation Kit (10M08SAE144) and building it with Quartus Prime Lite 19.1 + Nios2 Eclipse. I want to initialize the on-chip flash using POF. However, when I try to make one f...
YuanLi_S_Intel
6 years agoHi Mikhail,
By right a non-time limited sof will be generated after the compilation. Unless there is compilation error, can you please check your folder?
Thank You.
