GLees
Contributor
8 years agoIs anybody else completely dissatisfied with this new forum?
This used to be a robust forum, lots of new questions everyday and, most impotantly, lots of responses. This new forum is clunky and time consuming to navigate. Nobody seems interested anymore. I ...
corestar
Contributor
7 years agoWell, here is goes with random code off the internet:
-- GCD CALCULATOR (ESD book figure 2.11)
-- Weijun Zhang, 04/2001
-- we can put all the components in one document(gcd2.vhd)
-- or put them in separate files
-- this is the example of RT level modeling (FSM + DataPath)
-- the code is synthesized by Synopsys design compiler
-- Component: MULTIPLEXOR --------------------------------------------
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity mux is
port( rst, sLine: in std_logic;
load, result: in std_logic_vector( 3 downto 0 );
output: out std_logic_vector( 3 downto 0 )
end mux;
architecture mux_arc of mux is
begin
process( rst, sLine, load, result )
begin
if( rst = '1' ) then
output <= "0000"; -- do nothing
elsif sLine = '0' then
output <= load; -- load inputs
else
output <= result; -- load results
end if;
end process;
end mux_arc;
-- Component: COMPARATOR ---------------------------------------------
library IEEE;
entity comparator is
port( rst: in std_logic;
x, y: in std_logic_vector( 3 downto 0 );
output: out std_logic_vector( 1 downto 0 )
end comparator;
architecture comparator_arc of comparator is
begin
process( x, y, rst )
begin
output <= "00"; -- do nothing
elsif( x > y ) then
output <= "10"; -- if x greater
elsif( x < y ) then
output <= "01"; -- if y greater
else
output <= "11"; -- if equivalance.
end if;
end process;
end comparator_arc;
-- Component: SUBTRACTOR ----------------------------------------------
library IEEE;
entity subtractor is
cmd: in std_logic_vector( 1 downto 0 );
xout, yout: out std_logic_vector( 3 downto 0 )
end subtractor;
architecture subtractor_arc of subtractor is
begin
process( rst, cmd, x, y )
begin
if( rst = '1' or cmd = "00" ) then -- not active.
xout <= "0000";
yout <= "0000";
elsif( cmd = "10" ) then -- x is greater
xout <= ( x - y );
yout <= y;
elsif( cmd = "01" ) then -- y is greater
xout <= x;
yout <= ( y - x );
else
xout <= x; -- x and y are equal
yout <= y;
end if;
end process;
end subtractor_arc;
-- Component: REGISTER ---------------------------------------------------
library IEEE;
entity regis is
port( rst, clk, load: in std_logic;
input: in std_logic_vector( 3 downto 0 );
end regis;
architecture regis_arc of regis is
begin
process( rst, clk, load, input )
begin
output <= "0000";
elsif( clk'event and clk = '1') then
if( load = '1' ) then
output <= input;
end if;
end if;
end process;
end regis_arc;
-- component: FSM controller --------------------------------------------
library IEEE;
entity fsm is
port( rst, clk, proceed: in std_logic;
comparison: in std_logic_vector( 1 downto 0 );
enable, xsel, ysel, xld, yld: out std_logic
end fsm;
architecture fsm_arc of fsm is
type states is ( init, s0, s1, s2, s3, s4, s5 );
signal nState, cState: states;
begin
process( rst, clk )
begin
cState <= init;
elsif( clk'event and clk = '1' ) then
cState <= nState;
end if;
end process;
process( proceed, comparison, cState )
begin
case cState is
when init => if( proceed = '0' ) then
nState <= init;
else
nState <= s0;
end if;
when s0 => enable <= '0';
xsel <= '0';
ysel <= '0';
xld <= '0';
yld <= '0';
nState <= s1;
when s1 => enable <= '0';
xsel <= '0';
ysel <= '0';
xld <= '1';
yld <= '1';
nState <= s2;
when s2 => xld <= '0';
yld <= '0';
if( comparison = "10" ) then
nState <= s3;
elsif( comparison = "01" ) then
nState <= s4;
elsif( comparison = "11" ) then
nState <= s5;
end if;
when s3 => enable <= '0';
xsel <= '1';
ysel <= '0';
xld <= '1';
yld <= '0';
nState <= s2;
when s4 => enable <= '0';
xsel <= '0';
ysel <= '1';
xld <= '0';
yld <= '1';
nState <= s2;
when s5 => enable <= '1';
xsel <= '1';
ysel <= '1';
xld <= '1';
yld <= '1';
nState <= s0;
when others => nState <= s0;
end case;
end process;
end fsm_arc;
-- GCD Calculator: top level design using structural modeling
-- FSM + Datapath (mux, registers, subtracter and comparator)
library IEEE;
use work.all;
entity gcd is
port( rst, clk, go_i: in std_logic;
x_i, y_i: in std_logic_vector( 3 downto 0 );
d_o: out std_logic_vector( 3 downto 0 )
end gcd;
architecture gcd_arc of gcd is
component fsm is
end component;
component mux is
end component;
component comparator is
end component;
component subtractor is
end component;
component regis is
end component;
signal xld, yld, xsel, ysel, enable: std_logic;
signal comparison: std_logic_vector( 1 downto 0 );
signal result: std_logic_vector( 3 downto 0 );
signal xsub, ysub, xmux, ymux, xreg, yreg: std_logic_vector( 3 downto 0 );
begin
-- doing structure modeling here
-- FSM controller
TOFSM: fsm port map( rst, clk, go_i, comparison,
enable, xsel, ysel, xld, yld );
-- Datapath
X_MUX: mux port map( rst, xsel, x_i, xsub, xmux );
Y_MUX: mux port map( rst, ysel, y_i, ysub, ymux );
X_REG: regis port map( rst, clk, xld, xmux, xreg );
Y_REG: regis port map( rst, clk, yld, ymux, yreg );
U_COMP: comparator port map( rst, xreg, yreg, comparison );
X_SUB: subtractor port map( rst, comparison, xreg, yreg, xsub, ysub );
OUT_REG: regis port map( rst, clk, enable, xsub, result );
d_o <= result;
end gcd_arc;
---------------------------------------------------------------------------- corestar7 years ago
Contributor
@NRaml, looks like code insert is still broken to me. On my system (Windows 7 and FireFox or IE) it shows all 306 lines with no scrollbar.
- HRZ7 years ago
Same here, completely expanded by default and no scrollabr.
- Pvand17 years ago
ff63 android 8 same thing, no scrollbar. But I think i prefer it this way. Maybe 300+ lines is a bit too much, this might be something where view more functionality might be useful. Default only showa few lines and then have a button/link to toggle showing the complete thing.
