Leon_Yv
2 years agoIP simulation model
I'm running Quartus 18.1 Std and the project is targeted to MAX10 device. I need to use ALTPLL from the standard IP Catalog. On the previous Quartus versions I used Megawizard to configure/instantiat...
RichardT_altera
2 years agoThe Megawizard does not generate simulation model unfortunately.
Newer device like Arria 10 with the IP Parameter Editor has the option to do that but some older/legacy devices that use megawizard does not have the flexibility to do so.
I don't quite understand your intention when you said you are not simulating anything. What would you like to achieve by generating the simulation model for IP?
Most people generate the simulation model to simulate the IP and test the IP functionality.
Richard Tan
