17 years agoI/O pins Pull-Up Resistors
I am designing an embedded board with the MAX II EPM240T100C5N device. I am going to use some of the pins on the device to drive Output pins and to read Input pins. I would like to know if I should place pull-up/pull-down resistors on these pins and if so what values should I use? A colleague mentioned that the EPM240T100C5N has internal pull-up resistors. If so, how do I specify to use them? I am using Quartus II 8.0sp1 and I can not find a way to set the "Programmable Pull-Up Resistor" for each pin. Thank you, Eitan
