Invalid license environment. Application closing. (quartus 21.1)
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
- Zawani_M_Intel
Hello Firman,
This issue will be supported through private email as some confidential info is required.
Thanks!
Wani
- gabi1953
I have the same problem
gabi1953
- gabi1953
Hi
I am trying to use quartus lite ver21.1 ,when I try to run simulation I get " Invalid license environment
I have downloaded a valide license but still not able to run simulation
Gabi
- emrv23
hi, I have the same problem, help me please
thanks
- RakeshD
Hi Wani,
I have the same issue. Do we have a fix for it?
- Rakesh
- RakeshD
In my case, ModelSim was not installed (It does not get installed automatically with Quartus 21.1 as it does with older versions). After installing it manually and setting the path in Quartus, the problem disappeared.
- Rakesh
- blacklake
Hi Rakesh,
I've tried looking for the modelsim installer but I can't find it anywhere. Could you help me here?
-Quwam
- jhefer
Hola tengo un problema al compilar
me aprese el siguiente mensaje
"Error: Invalid license environment. Application closing."
como puedo solucionar esto , ayuda - kyarish
Hello!
I have the same problem with Quartus on Ubuntu 22.04.
I would be grateful for help!
