firman
4 years agoInvalid license environment. Application closing. (quartus 21.1)
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a ...
RakeshD
4 years agoHi Wani,
I have the same issue. Do we have a fix for it?
- Rakesh
RakeshD
4 years agoIn my case, ModelSim was not installed (It does not get installed automatically with Quartus 21.1 as it does with older versions). After installing it manually and setting the path in Quartus, the problem disappeared.
- Rakesh
- blacklake4 years ago
Hi Rakesh,
I've tried looking for the modelsim installer but I can't find it anywhere. Could you help me here?
-Quwam
- RakeshD4 years ago
Hi Quwam,
You can download Modelsim from:
https://fpgasoftware.intel.com/20.1.1/?edition=lite&platform=windows
After installation, you can set the Modelsim path in Quartus (Tools -> Options -> General -> EDA Tools Options).
- Rakesh
Thanks a lot!
