11 years agoInternal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/utils
Any ideas why it may happen?
I just added a PLL to my project based on golden design for Cyclone V SoC devkit. Now, I cannot move forward in compiling the design even when removing PLL instance from top level module. --Dmitry Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/utils_profiling.c, Line: 538 Internal Error Stack Trace: 0x119632: vpr_qi_jump_to_exit + 0x58 (fitter_vpr20kmain) 0x43daaf: vpr_final_exit + 0x8 (fitter_vpr20kmain) 0x4460e2: vpr_exit_at_line + 0x57 (fitter_vpr20kmain) 0x1d7c58: profile_close_bin + 0x338 (fitter_vpr20kmain) 0x235dc3: vpr_report + 0x13 (fitter_vpr20kmain) 0x792f8: VPR_QI_FACADE::vpr_qi_main() + 0x28 (fitter_vpr20kmain) 0x3d870: fitapi_run_vpr + 0x60 (fitter_fitapi) 0x3febe: FSV_EXPERT_BASE::place_and_route(bool*) const + 0x16e (fitter_fsv) 0x444e0: FSV_EXPERT_BASE::invoke_fitter() const + 0x17e0 (fitter_fsv) 0x3e402: fsv_execute + 0x292 (fitter_fsv) 0x2cac5: fmain_start(CMP_FACADE*) + 0x565 (fitter_fmain) 0x1b840: qfit_execute_fit(QCU_FRAMEWORK*, QFIT_FRAMEWORK*) + 0x150 (comp_qfit_legacy_flow) 0x15afd: QFIT_FRAMEWORK::execute() + 0x2ad (comp_qfit_legacy_flow) 0x25651: qfit_legacy_flow_run_legacy_fitter_flow + 0x1a1 (comp_qfit_legacy_flow) 0x2e8f6: TclInvokeStringCommand + 0x76 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x34310: TclEvalEx + 0x4f0 (tcl8.5) 0x34d13: TclEvalObjEx + 0x393 (tcl8.5) 0x3ac31: Tcl_EvalObjCmd + 0x91 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x73abf: TclExecuteByteCode + 0x151f (tcl8.5) 0xb5bc7: TclObjInterpProcCore + 0x107 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x73abf: TclExecuteByteCode + 0x151f (tcl8.5) 0xb5bc7: TclObjInterpProcCore + 0x107 (tcl8.5) 0x32b1e: TclEvalObjvInternal + 0x2be (tcl8.5) 0x34310: TclEvalEx + 0x4f0 (tcl8.5) 0x98c70: Tcl_FSEvalFileEx + 0x230 (tcl8.5) 0x98d6e: Tcl_EvalFile + 0x2e (tcl8.5) 0xff62: qexe_evaluate_tcl_script(char const*) + 0x43b (comp_qexe) 0x15515: qexe_do_tcl(QEXE_FRAMEWORK*, char const*, char const*, _Dinkum_std::list<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > > const&, bool, bool) + 0x507 (comp_qexe) 0x16352: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, _Dinkum_std::list<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >*, bool) + 0x542 (comp_qexe) 0x32bbe: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, _Dinkum_std::list<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >*, bool) + 0x7b1 (comp_qcu) 0x18b1f: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x641 (comp_qexe) 0x9517: qfit2_main(int, char const**) + 0xe7 (quartus_fit) 0x3bb9a: msg_main_thread(void*) + 0x10 (ccl_msg) 0x75bc: thr_final_wrapper + 0xc (ccl_thr) 0x3c801: msg_thread_wrapper(void* (*)(void*), void*) + 0x5b (ccl_msg) 0x18bf5: mem_thread_wrapper(void* (*)(void*), void*) + 0xc5 (quartus_fit) 0xf41d: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err) 0x799c: thr_thread_wrapper + 0x15 (ccl_thr) 0x4e41d: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x96 (ccl_msg) 0x21ec5: __libc_start_main + 0xf5 (c.so.6) 0x8d69: __gxx_personality_v0 + 0x311 (quartus_fit) End-trace Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
