11 years agoThe message itself make no sence for me as device is used for about 10% only.
Info (332129): Detected timing requirements -- optimizing circuit to achieve only the specified requirements Info (332111): Found 24 clocks Info (332111): Period Clock Name Info (332111): ======== ============ Info (332111): 40.000 altera_reserved_tck Info (332111): 20.000 fpga_clk_50 Info (332111): 1000.000 hps_i2c0_SCL Info (332111): 2.500 hps_memory_mem_ck Info (332111): 2.500 hps_memory_mem_ck_n Info (332111): 2.500 hps_memory_mem_dqs[0]_IN Info (332111): 2.500 hps_memory_mem_dqs[0]_OUT Info (332111): 2.500 hps_memory_mem_dqs[1]_IN Info (332111): 2.500 hps_memory_mem_dqs[1]_OUT Info (332111): 2.500 hps_memory_mem_dqs[2]_IN Info (332111): 2.500 hps_memory_mem_dqs[2]_OUT Info (332111): 2.500 hps_memory_mem_dqs[3]_IN Info (332111): 2.500 hps_memory_mem_dqs[3]_OUT Info (332111): 2.500 hps_memory_mem_dqs[4]_IN Info (332111): 2.500 hps_memory_mem_dqs[4]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[0]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[1]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[2]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[3]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[4]_OUT Info (332111): 20.833 hps_usb1_CLK Info (332111): 2.500 soc_inst|hps_0|hps_io|border|hps_sdram_inst|hps_sdram_p0_sampling_clock Info (332111): 2.500 soc_system:soc_inst|soc_system_hps_0:hps_0|soc_system_hps_0_hps_io:hps_io|soc_system_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_pll:pll|afi_clk_write_clk Info (332111): 2.500 soc_system:soc_inst|soc_system_hps_0:hps_0|soc_system_hps_0_hps_io:hps_io|soc_system_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_pll:pll|pll_write_clk_dq_write_clk Info (332111): Period Clock Name Info (332111): ======== ============ Info (332111): 40.000 altera_reserved_tck Info (332111): 20.000 fpga_clk_50 Info (332111): 1000.000 hps_i2c0_SCL Info (332111): 2.500 hps_memory_mem_ck Info (332111): 2.500 hps_memory_mem_ck_n Info (332111): 2.500 hps_memory_mem_dqs[0]_IN Info (332111): 2.500 hps_memory_mem_dqs[0]_OUT Info (332111): 2.500 hps_memory_mem_dqs[1]_IN Info (332111): 2.500 hps_memory_mem_dqs[1]_OUT Info (332111): 2.500 hps_memory_mem_dqs[2]_IN Info (332111): 2.500 hps_memory_mem_dqs[2]_OUT Info (332111): 2.500 hps_memory_mem_dqs[3]_IN Info (332111): 2.500 hps_memory_mem_dqs[3]_OUT Info (332111): 2.500 hps_memory_mem_dqs[4]_IN Info (332111): 2.500 hps_memory_mem_dqs[4]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[0]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[1]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[2]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[3]_OUT Info (332111): 2.500 hps_memory_mem_dqs_n[4]_OUT Info (332111): 20.833 hps_usb1_CLK Info (332111): 2.500 soc_inst|hps_0|hps_io|border|hps_sdram_inst|hps_sdram_p0_sampling_clock Info (332111): 2.500 soc_system:soc_inst|soc_system_hps_0:hps_0|soc_system_hps_0_hps_io:hps_io|soc_system_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_pll:pll|afi_clk_write_clk Info (332111): 2.500 soc_system:soc_inst|soc_system_hps_0:hps_0|soc_system_hps_0_hps_io:hps_io|soc_system_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_pll:pll|pll_write_clk_dq_write_clk Info (176233): Starting register packing Info (176235): Finished register packing Extra Info (176218): Packed 24 registers into blocks of type EC Extra Info (176218): Packed 24 registers into blocks of type EC Info (11798): Fitter preparation operations ending: elapsed time is 00:00:24 Info (170189): Fitter placement preparation operations beginning Info (170190): Fitter placement preparation operations ending: elapsed time is 00:00:02 Info (170191): Fitter placement operations beginning Info (170137): Fitter placement was successful Info (170192): Fitter placement operations ending: elapsed time is 00:00:05 Info (170193): Fitter routing operations beginning Error (11128): The following signal cannot be routed: soc_system:soc_inst|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|h2f_rst_n[0]. The device does not contain the routing resources required to make this connection
