11 years agoHi,
Even though the error message may not make sense from a device utilization perspective, it does (hopefully) point you in the right direction. Do you use this reset signal to reset the PLL you added to the design? Would it be possible for you to try another reset strategy in that case? I see in the initial post that you seem to get the IE even when the PLL is removed. Try to delete all Quartus generated folders in your project directory (db, incremental_db etc) and start the compilation again. Cheers
