Internal Error: Sub-system: SUTIL, File: /quartus/synth/sutil/sutil_wiring_helper.cpp, Line: 242
Hi, while synthesising on Quartus Version 19.1.0 Build 240 03/26/2019 SJ Pro Edition for Arria 10 10AX115N2F45E1SG (Terasic de5a-net-ddr4 board) i get this internal error message which I don't understand, can someone help? Error occurring both on Linux Debian 10 and Windows 10.
Error message:
cdb_is_connected (old_iterm)
Stack Trace:
0x5f44b: sutil_copy_fanin + 0x167 (SYNTH_SUTIL)
0x9888c: algs_ram_copy_fanin + 0x9c (SYNTH_ALGS)
0x9dd9e: ALGS_RAM_OPT_CONVERT_TDP_TO_SDP::copy_ram_input_ports_from_tdp_to_sdp + 0x3e (SYNTH_ALGS)
0x9d1fc: ALGS_RAM_OPT_CONVERT_TDP_TO_SDP::convert_tdp_with_unused_ports_to_sdp + 0x27c (SYNTH_ALGS)
0x9ce8b: ALGS_RAM_OPT_CONVERT_TDP_TO_SDP::optimize + 0xab (SYNTH_ALGS)
0x994a7: ALGS_RAM_OPTIMIZATION::optimize + 0xe7 (SYNTH_ALGS)
0x98f6c: ALGS_RAM_OPTIMIZATION::run + 0xbc (SYNTH_ALGS)
0x647cc: opt_pre_optimize_ram_nodes + 0x1dc (SYNTH_INFER)
0x5db3: OPT_RAM_INFERENCE::infer_ram_blocks + 0xb3 (SYNTH_INFER)
0x4cf9b: RTL_SCRIPT::call_ram_rom_fns + 0x42f (SYNTH_OPT)
0x49e66: RTL_SCRIPT::call_named_function + 0x8d6 (SYNTH_OPT)
0x48c56: RTL_SCRIPT::process_script + 0x5ba (SYNTH_OPT)
0x9c495: opt_run_pre_parallel_rtl + 0x23d (SYNTH_OPT)
0xbc91c: SYNTH::QIS::SYNTHESIS_FLOW::high_level_synthesis + 0x28c (synth_qis)
0xbf8d2: SYNTH::QIS::SYNTHESIS_FLOW::run_current_phase + 0x282 (synth_qis)
0xbfd3d: SYNTH::QIS::SYNTHESIS_FLOW::run_full_flow + 0x30d (synth_qis)
0x525a7: QIS_RTL_STAGE::IMPL::synthesize + 0x4b7 (synth_qis)
0x1b178: qis_synthesize + 0x1d8 (synth_qis)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5136: Tcl_EvalFile + 0x36 (tcl86)
0x14ebc: qexe_evaluate_tcl_script + 0x3fc (comp_qexe)
0x13f72: qexe_do_tcl + 0x4b2 (comp_qexe)
0x1a34e: qexe_run_tcl_option + 0x5ee (comp_qexe)
0x18185: QCU::DETAIL::intialise_qhd_and_run_qexe + 0x95 (comp_qcu)
0x28f9c: qcu_run_tcl_option + 0x2ec (comp_qcu)
0x19c58: qexe_run + 0x438 (comp_qexe)
0x1ad8a: qexe_standard_main + 0x26a (comp_qexe)
0x34d9: qsyn2_main + 0x129 (quartus_syn)
0x149f8: msg_main_thread + 0x18 (CCL_MSG)
0x1609e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x20fa0: mem_thread_wrapper + 0x70 (ccl_mem)
0x13f7d: msg_exe_main + 0x20d (CCL_MSG)
0x4dd4: __scrt_common_main_seh + 0x11c (quartus_syn)
0x17bd3: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6ce50: RtlUserThreadStart + 0x20 (ntdll)
End-trace
- KennyT_altera
IE usually is a bug. Can you attached us the design.qar files for duplication?
Also, can you upgrade the Quartus to 20.1 (latest version)
- KennyT_altera
any update?
- KennyT_altera
We do not receive any response from you to the previous question that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
- KennyT_altera
